Author Topic: Shay Locomotive  (Read 41010 times)
Re: Shay Locomotive
« Reply #120 on: January 09, 2018, 10:57:17 PM »
That's quite a machine!
Offline Dan Rowe
  • Dripping Springs TX USA
Re: Shay Locomotive
« Reply #121 on: January 10, 2018, 03:34:47 PM »
Chris,
Yes I drill a lot of small holes two jobs on this Shay build come to mind drilling the frames and drilling the steam cylinder. I did them with the Servo drill press but the work was not very securely held and that can lead to more in the scrap bin.
Cheers Dan
ShaylocoDan
Offline steamboatmodel
Re: Shay Locomotive
« Reply #122 on: January 10, 2018, 03:57:47 PM »
Hi Dan,
I can see lead screws for the Y & Z axes, but do not see any for the X? Does the spindle with the horizontal motor move?  It almost looks like you could do milling on it. I looked up the company but did not see any machinery on there.
Gerald.
Offline Dan Rowe
Re: Shay Locomotive
« Reply #123 on: January 10, 2018, 04:07:53 PM »
Gerald, the table is on round linear bearings and you simply push it into the drill bit. There is a mount in front for a dial indicator and a rod on the table that is adjustable that engages the dial point. The back rail has two stops to limit the table travel.
Here is a link to the specs:
https://www.westhoffinc.com/files/2012/09/MicroFlush.pdf?x21635
Cheers Dan
ShaylocoDan
Re: Shay Locomotive
« Reply #124 on: January 11, 2018, 03:09:48 PM »
Thanks Dan,
That is one very interesting machine.
Gerald.
Offline Dan Rowe
Re: Shay Locomotive
« Reply #125 on: January 12, 2018, 09:31:32 PM »
Progress on the wheel sets. I just have to trim the length and diameter of the bearing fits. I just had to see a trial assembly.
I will be packing up my mobile shop tomorrow for the trip to the International G1 Steamup at Diamondhead MS.
Cheers Dan
ShaylocoDan
Re: Shay Locomotive
« Reply #126 on: January 12, 2018, 10:57:37 PM »
Dan,
That just looks really cool!
So, I'm sure it's back in your thread somewhere, but did you make all those castings?  They look really great!
Offline Dan Rowe
Re: Shay Locomotive
« Reply #127 on: January 12, 2018, 11:31:07 PM »
Kim, I did all the castings except for the gears and the line shaft bearings. I only cast silicon bronze which is a bit hard for a bearing so I used Shapeways for the line shaft bearings. The gears were cast from a part made with a 3D printer. I would have used Shapeways but they do not cast a white bronze which I think looks better,
Cheers Dan
ShaylocoDan
