This is just for discussion. I'm not building anything based on this.
Many of the small engines that are seen on here include a water jacket that surrounds the cylinder for cooling,
For many years on my cruising sailboat, I operated a diesel genset powered by a 6HP single cylinder Farymann Diesel that ran at 1800RPM and was rated at 4.5 KW The engine was cooled with a freshwater circulation with a seawater heat exchanger and it provided good service for as long as I owned it with normal maintenance issues.
The thing that I thought unusual was that there was no cooling water jacket on the cylinder. All of the cooling water circulated through the head only. I asked the factory rep about it and he said that almost all of the heat was generated in the head and that by not passing water flow through a head gasket joint, they eliminated the problems that could come from a head gasket water leak. It must have worked because the engine was painted white and after about 3000 engine hours, the paint was still white on the cylinder and showed just a little heat discoloration on the valve cover.
My question is, has anyone ever considered this for model engine design?
Jerry
