Author Topic: 1 Ton or 2?  (Read 2907 times)
Arbalest
1 Ton or 2?
« on: March 15, 2013, 04:13:48 PM »
Been thinking that a small arbor press would be useful for stamping numbers etc into steel or alloy parts etc. Whadoyareckon, 1 or 2 ton? Anyone have experience of these things?
Offline Walsheng
  • Norfolk, MA
    • Walsh Engineering
Re: 1 Ton or 2?
« Reply #1 on: March 15, 2013, 04:51:41 PM »
You can do 1 ton work on a 2 ton press but not the other way around.
More depends on your budget and room.
Arbalest
Re: 1 Ton or 2?
« Reply #2 on: March 15, 2013, 05:19:52 PM »
Space is at a premium at the moment. Can the 1 ton unit press say 4mm numbers into mild steel is the question?
Re: 1 Ton or 2?
« Reply #3 on: March 15, 2013, 05:47:14 PM »
Are you going to use like the single number stamps or what?  If so, a good blow with a hammer is far better than an arbor press for that.
Offline Chris J
  • Great Yarmouth - England
Re: 1 Ton or 2?
« Reply #4 on: March 15, 2013, 06:00:12 PM »
If space is tight a hammer might be the way to go.
What about etching?
Don't believe everything you read on the internet - Abraham Lincoln.
Arbalest
Re: 1 Ton or 2?
« Reply #5 on: March 28, 2013, 07:54:40 PM »
Saw a nice used 2 ton so it followed me home ...  :naughty:
Re: 1 Ton or 2?
« Reply #6 on: March 28, 2013, 07:59:58 PM »
Never hurts to have one on hand, especially if you found a good one for a reasonable price used. I still think though that for stamping letters/numbers a good hammer blow is the best option.  You will find plenty of other uses for the arbor press I am sure :)
Offline Maryak
Re: 1 Ton or 2?
« Reply #7 on: March 29, 2013, 05:19:37 AM »
I agree with one addition, a staking tool; so that the numbers are hammered in the right spot on the workpiece.
Best Regards
