Author Topic: Setting tool height on the lathe.  (Read 4859 times)
Offline Doc
  • USA ND
« on: February 25, 2013, 01:24:22 AM »
If you have a 6 inch scale in your pocket you already have the best height setting tool in MHO.
I was taught this back when I first started in the machine shop over 39 years ago and used it through out my career and it has never let me down. Since I seen several posts about building or creating a height setting tool I decided to try and make a short little vid showing the process.
<a href="https://www.youtube.com/watch?v=vpCu56O8AJ0" target="_blank">http://www.youtube.com/watch?v=vpCu56O8AJ0</a>
Offline Chris J
  • Great Yarmouth - England
Re: Setting tool height on the lathe.
« Reply #1 on: February 25, 2013, 01:38:58 AM »
Very good, thanks
Don't believe everything you read on the internet - Abraham Lincoln.
Arbalest
« Reply #2 on: February 25, 2013, 10:32:10 AM »
I use the same technique for drilling a hole in a round bar except it's a bit easier with the rule laying flat across the bar!
Offline PJW
« Reply #3 on: February 25, 2013, 10:46:42 AM »
thanks doc I will remember that  :ThumbsUp:
Old Guys Rule the Dark Side of the Shed!
Offline Pete49
« Reply #4 on: February 26, 2013, 03:09:41 AM »
I used to use that trick. Shown to me by a fitter & turner mate of mine
Offline kevin45
« Reply #5 on: May 28, 2013, 07:37:26 PM »
I'll have to remember that trick. Thank you for posting it.
The way I have been doing it is take a sharp #2 pencil, and with the lathe running, take the pencil and draw on the end of the part until you find the center, then set your tool according to the small circle. I also will leave the tool just slightly below center then leave a small tit on the end. Then if I have a few diameters to turn, I will use that small tit as a reference point and draw the diameters, again with the lathe on to show where your rough cuts will be. It saves a lot of time from, having to stop and check every few cuts. Just add a 1/32" or so when you make a mark from the center tit.
Offline SteveM
  • Jr. member
« Reply #6 on: October 14, 2013, 12:31:56 AM »
That is a great tip Doc, many thanks.
I'd like to ask you about that toolpost we can see in the video. It looks like a really nice piece of kit, and I can't recall seeing one quite like that before. Is it commercially available, or did you make it yourself?
« Reply #7 on: October 14, 2013, 02:19:00 AM »
I learned that trick on the past forum. Really handy and worth repeating for newbies.
Thanks Doc.
Special thanks for the video. Always best to 'see' rather than 'hear' (er...'read').
