Good idea... Hmm that lathe looks very familiar...southbend 10k??
How did you set the level parallel to the lathe CL to tool top plane?
Stupid question but what happens if your lathe is not level?Best RegardsBob
In an earlier bit of a reply, I gave two solutions- both very elementary ones. The first was the blade held at a tangent in a vertical position
I use a centering scope that I got from ENCO a year or two ago. Stick it in the tailstock chuck and you can see tool height. They are not only good for centering!!cheersBill
That strikes me as a fundamental problem if you use a level.I seem to recall that Arbalest had a neat solution to tool height that sat on the lathe bed.I think that would eliminate that problem. ?
Quote from: Chris J on February 22, 2013, 07:15:13 AMThat strikes me as a fundamental problem if you use a level.I seem to recall that Arbalest had a neat solution to tool height that sat on the lathe bed.I think that would eliminate that problem. ?Yes Chris, this is mine. It also shows how quick a Tangential tool is to set up if you only have a four way tool post.
I made my tangential tool holders so the top of the holder is exactly at centre height. So I just have to put the holder upside down on something suitable (like brass) and press the tool down until it hits the surface and the job is done. Works for me.Jim
