Author Topic: Straight 6,,maybe  (Read 40496 times)
Offline Camm-1
  • Sweden
Straight 6,,maybe
« on: February 17, 2013, 07:49:01 PM »
Hi!
I have started a bit on a new projekt, an Inline 6.
I use R Cox open six drawings for crank and cam but will try to build it closed watercooled.
I dont have any drawings for that but I  just go ahead anyway and hope it will work.
Carved out the block today (30 L chips)
Re: Straight 6,,maybe
« Reply #1 on: February 17, 2013, 08:22:45 PM »
Nice start.  Will be following you as you progress.
« Reply #2 on: February 17, 2013, 08:45:39 PM »
Always glad to see a project start. I'll be watching.
Offline metalmad
« Reply #3 on: February 17, 2013, 11:26:40 PM »
Hi Camm
Looking forward to the new Build!
Offline stevehuckss396
  • Sterling Heights, MI USA
« Reply #4 on: February 17, 2013, 11:37:34 PM »
Yes sir!  First straight 6 i have ever seen.
Offline ScroungerLee
« Reply #5 on: February 18, 2013, 01:25:02 PM »
Nice looking so far.  Thanks for including the pen so we can get a sense of the size.  I will be following along.
Lee
Mmmmm.... Shiny!
Offline cfellows
« Reply #6 on: February 18, 2013, 03:55:10 PM »
Should be an interesting project.  I built a 2 cylinder inline version of Randall's engine, pretty much like his.  Just curious, why do you want to close it up and water cool it?
Chuck
Offline Camm-1
  • Sweden
« Reply #7 on: February 18, 2013, 04:55:22 PM »
Chuck, I want it to look  more real and as I have run the Hoglet for a while I dont like the oil messing around.
I also go for an usual distributor and timingbelt intead of chain as in the drawings.
The most different is the crankcase that I will built up and put rollerbearings on the crank 5p and also on the cam and
make ,hmm dont know the name for caps or how to say over the bearings.
Well as someone said, I dont know what I´m doing just doing it :facepalm:
Ove
Offline KB
« Reply #8 on: February 18, 2013, 06:21:19 PM »
Great start! An in line six will be a great engine.
I had several straight six cars. The engines were bullet proof but everything else on the car would rot out.
Offline crankshafter
  • Molde, Norway
« Reply #9 on: February 18, 2013, 07:19:20 PM »
Hei Ove.
Nice start on the inline6. :whoohoo:
I have pulled up the chair :ThumbsUp: :cheers:
Bård.
"I cut it twice, and it's still to short"!!??">#%
Offline Camm-1
  • Sweden
« Reply #10 on: February 18, 2013, 07:47:22 PM »
Thanks for interest boys!
Yea, I like the six, they run smoothest also had some big ones in tractors and a car.
I was down in the garage tonight making the first cyl liner and the pipe I had to it makes the ready bore to
27,65mm that makes 137 cc. Would sound good if I get it to run.
Offline Camm-1
  • Sweden
« Reply #11 on: February 22, 2013, 06:00:40 PM »
Some more progress.
Have turned the liners of steelpipe. Bore is ca 27.66mm.
Have to lap them a bit so I will try doing a expanding brass tool that I have seen here.
Will carburundum valve paste do it? Thats what I have.
Offline capin
« Reply #12 on: February 22, 2013, 10:17:39 PM »
 :cheers:  Awesome start to what will end up a great engine as you have done before. Thanks for taking us along with you. Brian
I'm as suprised as you that it runs !
Offline Camm-1
  • Sweden
Sv: Straight 6,,maybe
« Reply #13 on: February 23, 2013, 05:14:18 PM »
Pressed in the liners today and faced up the headblock.
« Reply #14 on: February 23, 2013, 05:42:17 PM »
Camm-1 you are moving along.
Did you use the same paste for your Hoglet?  I would use the same method you used in the Hoglet.
