Author Topic: Building my new workshop  (Read 41677 times)
Offline ths
« Reply #60 on: April 09, 2013, 12:44:33 AM »
What's all this about radon? Sounds insidious!
Tim, for a number of reasons, over here we'd do the slab first and then put the structure on top,of it, this way we can see the termites getting in. Don't you have them over there?
Hugh.
Re: Building my new workshop
« Reply #61 on: April 09, 2013, 01:31:48 AM »
Hugh.
Hugh I am with you, the radon I know about comes from radioactive material. And we do pour our slabs before building here and treat for termites.
By the way nice shed Tim you'll be making Swarf pretty soon.
Offline ths
« Reply #62 on: April 09, 2013, 04:44:39 AM »
And it is very remiss of me, probably through envy, to have failed to congratulate you on creating a great space. As I type this, I'm actually drawing (?) plans for my shed.
Cheers, Hugh.
Offline Rayanth
  • Lake Stevens, Washington, USA
« Reply #63 on: April 09, 2013, 07:58:30 AM »
For those who are confused about the talk about Radon : http://www.epa.gov/radon/pubs/citguide.html
Radon is a radioactive gas emitted by the decay of radioactive materials. Virtually all soils have trace amounts of radioactive materials in them, including uranium in infinitesimal amounts. According to the site, Radon is the second leading cause of lung-cancer and deaths from Radon-induced lung-cancer number 20,000+ per year in the US alone. Serious business!
-- Rayanth
---Please understand that I am a complete novice, and may take a very wrong path to doing things. Take my opinions and procedures with a grain of salt.
--- All photos taken with a Canon Rebel t1i and resized using "OptimumJPEG".
---Please alert me to any photos or links that do not load.
Offline spuddevans
  • Portadown, Northern Ireland
    • My photo website
« Reply #64 on: April 09, 2013, 01:13:30 PM »
Hi Hugh, thanks for the comments.
That's the way it is normally done here too, but in my case there was already a concrete slab here (evidently laid by a blind man who had never been introduced to a spirit level) where 20yrs ago there stood a garage (long since pulled down before I ever moved in)
So I built the shed 1st and then put a cement screed down to give a nice flat, level, and smooth floor.
Termites?  :thinking: :shrug: :noidea: I think St Patrick drove them out with the snakes, the only problem we suffer with is damp, rot, and woodworm. ( and the buildings get some problems too  :ROFL: )
Tim
Measure with a Micrometer, mark with chalk, cut with an axe. MI0TME
Offline spuddevans
    • My photo website
« Reply #65 on: April 09, 2013, 01:20:47 PM »
Little Update:
Got the floor screed down yesterday, it took 1.25 tonnes of cement (all shovelled by yours truly)
Now gotta wait for a week for it to harden enough to walk on. But I might find a couple of things to do around the outside.
Tim
« Reply #66 on: April 09, 2013, 01:30:21 PM »
Looks good Tim...after that much shoveling, maybe you should take today off :)  Did you do the floor in sections or as one continuous block?  Given the depth of the building, just wondering how your worked the concrete to smooth it, etc. once it was in place.
Offline ScroungerLee
« Reply #67 on: April 09, 2013, 01:35:13 PM »
You are getting near to the fun part of deciding what goes where, I am jealous :)
Lee
Mmmmm.... Shiny!
« Reply #68 on: April 09, 2013, 02:13:45 PM »
Looks awesome Tim!
Offline spuddevans
    • My photo website
« Reply #69 on: April 09, 2013, 07:26:07 PM »
Actually, I've just realised that I shovelled 2.5tonnes. The mixer we were using did not have a stand, so I shovelled the sand/cement from the trailer into the mixer, then tipped the resulting mixture onto the ground before shovelling it into a wheelbarrow and then wheeling said implement into the workshop and tipping it.
No wonder my back is aching  :facepalm2:
It was laid and smoothed in sections about 2ft each along the width of the shed. We 1st of all laid a couple of lengths of 2"x2" timber, positioned about 2ft in from each long wall, and levelled them up with some cement. Then it was just a case of spreading the cement inbetween. Then we could smooth it using another timber riding on the 2"x2"s. Then after smoothing, we troweled it up with a steel float to give it a finished surface.
Then after coming back we prised out the 2"x2"s and filled in the gaps, smoothing it and carefully smoothing over the area's where we had to tread on to fill the gaps, backing out towards the door.
My friend who did all the actual skilled work says the key to putting a floor in like this is to have the cement as dry as possible. I thought I was mixing it really dry, but it was really surprising to see the amount of water that would rise up to the surface as he was troweling it up. Of course it had nowhere else to go, the DPC stops it from going down. (It was coming out of the mixer so dry that it would hardly hold together in my hand, but I guess I could have mixed it drier  :shrug:
But because it is so dry, it meant that it could be walked on to remove the 2"x2"s and fill in without spoiling the whole area.
When I checked today, the surface is still soft, my friend reckons about a week to harden up enough to be walked on.
The depth of the screed is between 2" at the shallowest and about 4" at the deepest  :o  This surface is such an improvement (although to be fair, you could put a screed down with a jack-hammer and still get a better surface than what was there before :ROFL: )
Lee
Even before I had built the 1st wall panel I had started planning where everything would go, I'm even planning where the tools that I hope to make and buy will go!!
Thanks for the comments guys   :ThumbsUp:
Tim
Offline ths
« Reply #70 on: April 09, 2013, 09:34:11 PM »
Thanks for the explanation Tim, it all makes sense. And great work with the concrete, a lot of very hard work, but you now have what you want.
Hugh.
Offline NickG
« Reply #71 on: April 09, 2013, 11:09:32 PM »
Looks great that Tim, well done, bet you can't wait to use it. Looks cosy!
Offline spuddevans
    • My photo website
« Reply #72 on: April 29, 2013, 08:51:48 PM »
Little update:
For over a week I have ran my dehumidifier and have extracted an estimated 80-100 litres   :o
Then today I got the lend of my brothers trailer and brought over all the kitchen cabinets stored in my dad's garage. It took only two trips, and now I am faced with the age-old game of "Kitchen-Cabinet" Tetris.
Suddenly I feel the need for a bigger workshop   :facepalm:
Stay tuned for In-Game pictures over the next week !!
Tim
« Reply #73 on: April 29, 2013, 10:00:31 PM »
 :lolb: That's always the way.
Isn't it exciting though? You get to make it however way you want.
« Reply #74 on: April 29, 2013, 10:12:01 PM »
That looks awesome Tim!   Once you start hanging stuff on the walls....the floor space will free up..
 :ThumbsUp:
