Usually the only thing that goes pear shaped with florescent lighting is the ballast, which can be *shot* due to age and the other is the tubes themselves become worn out over time.
I don't know if you are going to heat this cozy little abode in the colder months or not ut keep in mind that regular florescent ballasts do not work well in colder temperatures. Ballast for these conditions can be purchased but are a bit pricey. I have been considering getting a coupe for our garage (insulated but unheated) because the lights do not want to come on when it gets fairly cold outside.
The space between the wallboard and the concrete floor slab is one of the places where the radon gets in, in many cases.M.
Are you screeding right up to the wall board?....
Can there be any more sad a sight than a workshop filled with nothingness ????
