Author Topic: morse taper drills  (Read 2757 times)
Offline krv3000
morse taper drills
« on: February 05, 2013, 10:51:27 PM »
hi all this is a tip on cleaning up and repairing Morse taper drills most of my tooling is second hand mostly from boot sales sum just need a scrub up wile others need a full rebuild to remove rust  i soke them in old battery acid  then give them a cote of anty rusting agent for the broken ones wel i remove the old drill bit and replace it with a new one don't no if you all no this but Small diameter drill bits are silver soldered in to the Morse taper   so to reaper them i remove the old one re drill the hole with the drill that Will be gowning in i then put a step in the top part OD the drill shank then silver solder  job dun right pics
Offline ths
morse taper drills
« Reply #1 on: February 06, 2013, 03:48:16 AM »
Bob, I really like it. Thanks,
Hugh.
Offline Stilldrillin
Re: morse taper drills
« Reply #2 on: February 08, 2013, 08:34:53 AM »
Good idea Bob!  :ThumbsUp:
David D
David.
