Author Topic: Vee Cutting  (Read 5309 times)
Arbalest
Offline Stilldrillin
Re: Vee Cutting
« Reply #1 on: January 24, 2013, 01:09:02 PM »
I used to do that sort of thing regularly, when I worked for a living.
A cobalt drill would perform better than "my" hss regrinds used to do!  :ThumbsUp:
Don't go deeper than the depth of the point angle. There's no side relief on a spotting drill........
David D
David.
Online mklotz
Re: Vee Cutting
« Reply #2 on: January 24, 2013, 04:04:50 PM »
Do they sell "drill mills"
http://www.use-enco.com/CGI/INSRIT?PMAKA=308-0227&PMPXNO=9404927&PARTPG=INLMK32
over there?  They're made to do what you wish to do.
Re: Vee Cutting
« Reply #3 on: January 24, 2013, 04:53:52 PM »
I used the kind of cutter Marv show above here:
http://www.modelenginemaker.com/index.php/topic,630.0.html
Re: Vee Cutting
« Reply #4 on: January 24, 2013, 05:27:35 PM »
Thanks guys, I've been wondering the same thing and I'm just getting ready to place an Enco order.
I think they are even on sale.
Eric
Re: Vee Cutting
« Reply #5 on: January 24, 2013, 05:28:04 PM »
They possibly do, Marv. But, I've never come across them......  :-\
David D
David.
Online mklotz
Re: Vee Cutting
« Reply #6 on: January 24, 2013, 05:55:02 PM »
Considering the differences between our languages, it's possible that they're known by an entirely different name.
Arbalest
Re: Vee Cutting
« Reply #7 on: January 24, 2013, 08:23:23 PM »
As said, they're not easy to get over here Marv.
I found this supplier a little while ago but look at the price!
http://www.cutweltools.co.uk/files/ww/FT%20A165.pdf
« Last Edit: January 24, 2013, 08:29:25 PM by Arbalest »
Offline arnoldb
  • Windhoek, Namibia
Re: Vee Cutting
« Reply #8 on: January 24, 2013, 08:40:07 PM »
 :headscratch: - a good quality 3-flute 90o countersink bit might also do the job...:
Sort of like this one: http://www.somta.co.za/cat/761.htm
Needs a bit of clearance for the tip though, so you might have to use a small slot mill to cut that.  Or even a slitting saw with the part in another  set-up.
Kind regards, Arnold
Offline peatoluser
  • liverpool UK
Re: Vee Cutting
« Reply #9 on: January 24, 2013, 10:14:47 PM »
I used a cheap countersink to cut this vee in the peatol, but as Arnold says, its best to cut a narrow slot with a slot drill/hacksaw/slitting saw etc.
I even cut a larger vee with a 1/2 dia. countersink, and although i cabbaged the teeth (forgot to change speeds when i swopped from small slot to countersink) it still produced a decent job.
yours
peter
Arbalest
Re: Vee Cutting
« Reply #10 on: January 27, 2013, 05:32:51 PM »
As luck would have there was a 10mm solid carbide one on eBay. I got it for ?10.00 inc post, list price is ?56.00 +!
