Hi Phil, Yes indeed that is the model - 'you lucky lucky guy' I see the flywheel is made from two halves but if I remember correctly Peters engine that I saw had a segmented flywheel the machining of which was simply perfect. The whole model was a joy to behold - superb workmanship. I may have a photo of it somewhere - do you have any?
Capt J - I found a whole load of old photographs today of the corliss engine in the Manchester museum but they'll all need scanning and times not on my side at present - see what I can do later in the week.regards - Ramon
RamonYou mentioned Peter's Tandem compound.That would be "Agnes" the model I am currently building, mine is one of only three in existence unless someone knows better.Peter built two of them, my father obtained the only remaining castings form Peter and started this one in the 1980's.It was sold in this condition 13 years ago when dad took ill, I have just managed to buy it back and intend to finish it myself.Watch this space, but don't hold your breath. I may be a while.By the way, I still have an original Fleet catalogue.Phil
There is a cure for this isn't there..........
