I decided to go ahead and just post a few pictures of where I am so far on my first ever engine build.
I haven't got very far with it, but I figure I might as well just start, and use this as a build log, kind of thing.
I started with the crankshaft bearing, mainly because on the day I started it was the only item I had a suitable piece of material for. Here is my first attempt.
It's a bit rough, but it is also my first piece of brass turning.
I therefore called it a successful day on that particular item, and celebrated accordingly
Safety note - beers only come out once all tools are cleaned and put away. No activities in the shop except for pondering and sweeping when the relaxation begins.
Anyhoo, the next item I turned my attention to was the connecting rod.
That is as far as I have got with that item. I need to thread the little end, and machine flats and drill a pivot hole in the big end. Elmers plans call for flats both sides of the connecting rod big end, but am only going to do one, mainly because I think it might be more arty looking. If it looks rubbish then I'll do 2.
It took me three goes to get the con rod this far. I destroyed the other 2 because holding the part and turning the longish, thin diameter were difficult, and after reading Jos thread about her home made follow rest today, will be making one of those for myself for small work. In the end I machined the con rod in 3 goes - three short lengths at a time, so to speak. I managed to get the three sections blended fairly well, so I'm happy enough for now.
By this time I had acquired some larger diameter aluminium and some steel, and so I had a try at the flywheel, and also the jig pin in Elmers plans. I realise a lot of people just make use of their mills to place all the holes accurately on the support frame, but since I don't have a mill yet I thought I would try using Elmers ingenious jig approach for laying out the holes.
This picture shows first flywheel, jig pin and the con rod and bearing.
At the time, I had decided to leave the flywheel as a plain disc as shown in the picture. However, since then I broke a drill bit off in the flywheel attempting to drill the hole for a set screw, so I shall be remaking the flywheel. I have decided that I would rather make it in brass anyway, and I am not going to shy away from attempting a groove each side of it either.
Next up, I had a go at the crankshaft. So far all I have done is the main shaft:
I have yet to make the crank disc for the end of it.
I have also started work on the frame for the engine, and have rough cut it to shape, and drilled the bearing hole, the inlet and exhaust port holes, and the cylinder pivot hole. I need to do some finishing work on it, which will be done the old fashioned way by hand with files, and then various grades of emery paper, and if that looks good I'll post a picture of it.
The engine has taken a bit of a back seat for now while I make some other tooling, plus I have been working on motorcycle maintenance and repair over the winter break, but I should be able to attempt some more work on the engine this weekend, which is exactly what I said last weekend.
Anyway, that's my wobbler so far.
