Author Topic: My Workshop  (Read 13452 times)
Offline propforward
  • MN, USA
My Workshop
« on: January 03, 2013, 07:29:53 PM »
Hello folks!
I just signed up with the forum today, having happened upon it while surfing the net for some answers to some questions.
I recognise a lot of names, so that's all good stuff. Thought I would show off my own workshop having signed up, and also because I can't help myself.
For about 10 years, between 2000 and 2010, I was living in a rented farmhouse, and had a shed that doubled as a garage and workshop. Pretty nice set up for the most part, but the shed was extremely dusty and dirty. It was converted from an old grainary. It was very draughty, and while it kept the worst of the weather off my tools and bikes, it was simply too cold (being in Minnesota - and the shed was totally uninsulated) in winter to work in. It was also damp as heck, and all I could do to keep the tools and bikes from just rusting away.
Prior to 2000 I was living in apartments and rented spaces etc, and just acquiring hand tools to keep motorcycles in service.
However, 2 years ago I moved house and finally bought my own place. The new house is a more modern (1996 construction vs 1905) building......with a very important additional feature.........
This:
A pole shed.............most excellent.
The shed had an electrical service, and concrete base, but that was it. It was unfinished. Actually - I was pretty happy about that. It meant that some construction would be reuired, but that way I could get a shop built inside it to my own specifications.
So, to make a long story longer, that is what I set about doing.
The pole shed is about 30' by 40', and I decided that insulating and heating that whole space would be too costly, and frankly pointless, so I decided to frame in a 16 X 30 section at the rear of the shed, which would house all my tools, and then the remainder of the shed would be for general storage of all the other guff - such as gardening implements, lawnmower and all that stuff that gets in the way of real fun sometimes. :rolleyes:
Anyway, less words prop, more pics.
So here is a view inside the shed, looking from the right most overhead door to the far corner.
Prime starting material for a shop, I think you'll agree.
I started off by making a temporary bench to hold carpentry tools
Designed the framing system
Got the building permit (decided to do it legally, even though a project like this you can sneak under the radar easily enough).
Ordered the material
And set about the 2 X 4s with a nailing gun.
And slowly things started to take shape.
Well, then a major project came up at work, which required me to travel extensively throughout 2011. I decided at that point, that having the shop built in time for winter of 2011/2012 was more important than the satisfaction of building the shop myself. Besides, it turns out that carpentry is not easy. I was happy with the frames I was making, but it was taking a long time to make each one. So I contracted the rest of the job out.
That's why there is a sudden leap from a few frames in the above picture to:
Which happened in the space of a week during one of my travels.
Moving on, once sheetrocking and electrical were installed:
Starting to take shape eh?
The contracting things out approach worked so well, that I did it with the heater, too.
So, painted and trimmed and heated, I got back in there and started moving tools and equipment in.
Once the tools were in (they were just "placed" at this point - not yet bolted down and installed) I made up the benches. I had some 16 foot 2 X 6's left over from the construction, and these made some very nice benches.
All that remained after that was to get a few shelves in, some pegboard on the walls, and get the machines bolted down and in place.
Here are the pics of the shop now:
I am very very very happy with this. It's a dream come true, and it has taken a long time to get to this point. The shop has a 9 foot ceiling, heating and air conditioning, and is very well insulated making the heat and a/c affordable. I have two 110V circuits of outlets all around the walls, three individual 220V circuits for machine tools, individual a/c circuit, individual air compressor circuit (air compressor is outside shop in main shed), separate lighting circuit. As you can see, it is bright and clean, with a place for everything and everything in its place.
This is a dream space that I have been actually working towards for some time, and I am really happy with it. There is still a lot to do and add, but these things happen over time. I am hoping to add a vertical mill in a couple of months, but first off I need to (re) learn some basic machining skills. I have made a start on an Elmer number 25, and I am pleased with the progress so far. It is a real challenge figuring out how to make some parts, but slowly it is coming together.
Thanks for having me!
« Last Edit: January 07, 2013, 01:33:47 PM by propforward »
Forging ahead regardless.
Offline AussieJimG
  • Bywong, NSW, Australia
Re: My Workshop - a long time dream come true.
« Reply #1 on: January 03, 2013, 07:41:14 PM »
That is one great space. Well designed, properly executed. :ThumbsUp:
And I do like the bike lift. I either need to get one or to stop working on bikes.
But what was all that white stuff outside the shed? :ROFL:
« Reply #2 on: January 03, 2013, 07:47:36 PM »
Very nice space Prop...something most of us only dream of!!  What did you do for the floor in the shop space?  It is epoxy coated or what? Looks great whatever it is as does the whole shop. I'm with Jim though...you can keep the white stuff outside :)
Offline propforward
  • MN, USA
« Reply #3 on: January 03, 2013, 07:48:49 PM »
It's evil stuff. It is anti bike matter.
Although it does encourage me to stay in the shop, so it's not all bad.
Offline propforward
  • MN, USA
« Reply #4 on: January 03, 2013, 07:53:49 PM »
It is indeed epoxy coated. I did that myself, it was never a part of the contractors scope of work.
It took me three solid days of prep to do it - scrubbing and scraping the concrete floor, then degreasing it, then etching it. That was all the hardest part, but well worth the effort. Doing the epoxy painting was relatively easy, but a word to the wise, if you do this yourself, paint very small sections at a time, then throw the paint chips. I painted sections that were far too large, and as a result I do not have uniform paint chip distribution. Even so, I am happy, it is much better than a bare concrete floor. I just used one of the garage floor epoxy paint kits that you can get at Home Depot or other home improvement stores. I recommend buying extra paint chips, and allow for about 1/3 extra paint over what they say on the box for good floor coverage. So far - no peeling or chipping of the paint anywhere, so it is holding up quite well.
« Reply #5 on: January 03, 2013, 08:43:51 PM »
Welcome!
NICE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
« Reply #6 on: January 03, 2013, 08:53:53 PM »
Welcome, you are giving me ideas for my new workshop, thanks.
Offline rudydubya
  • Western Arkansas USA
« Reply #7 on: January 03, 2013, 08:56:38 PM »
Wow!  That's quite a shop, Prop.  Congratulations.  And welcome.
Rudy
« Reply #8 on: January 03, 2013, 11:37:52 PM »
Ah here they are. (The pics of the shop.)
Nice! That's going to be a fun and happy place.
« Reply #9 on: January 04, 2013, 12:56:42 AM »
That is well set up shop Prop. You have room to work and having it cool and warm when you want makes it nice doesn't it? My shop is also a 30x40 metal building and I spli it in half one side for drive in and the other insulated to work in.
Offline propforward
  • MN, USA
« Reply #10 on: January 04, 2013, 01:41:29 AM »
Thanks for the kind words all! I am naturally very happy and proud of this space. Mostly I have been doing maintenance on my bikes in it, but it is really fun to be cutting (butchering? :)) metal in it now. It is indeed a real treat to be able to keep it warm and cool as needed.
Arbalest
« Reply #11 on: January 04, 2013, 02:09:42 PM »
Great looking workshop!
Offline ScroungerLee
« Reply #12 on: January 04, 2013, 03:51:12 PM »
That's a beautiful PropShop.  Interesting placement of the lathe e-stop on the wall, you could hit that after jumping away from an emergency event.
Lee
Mmmmm.... Shiny!
Offline propforward
  • MN, USA
« Reply #13 on: January 05, 2013, 01:47:18 PM »
Thanks Lee.
The wall mount breaker was actually a bit of overkill on my part. In retrospect I'm not sure it was worthwhile. The lathe has an e-stop on it anyway, and I can always pull the plug. Still, it's there, and I like shutting off the breaker when changing belts / gears etc, rather than pulling the plug.
I've attached a couple more recent pictures of the lathe area here. I made up a beefy set of rather ugly shelves from some left over 2 X 4s and plywood, to hold lathe tooling and some materials. Although it's not the most well crafted piece of carpentry by any means, it is handy to have.
Here is a close up of my lathe - a Grizzly 12 X 37 belt drive back gear machine, with gap bed. Quite a nice all round machine. I got it in 2008, but haven't done much with it until recently - it certainly is enjoyable to start working with it finally.
My Dad sent me over a small quick change toolpost, which I think is from a Myford lathe. Today I am going to try and make a suitable post to mount it to the Grizzly. I think having the small toolpost on there will make it easier for me to hold some of the smaller bits, which are a bit more appropriate for some of the small parts I am trying to make on my first engine(s). I'll post some pictures of that later on.
« Last Edit: January 28, 2013, 04:19:34 PM by propforward »
« Reply #14 on: January 05, 2013, 04:01:15 PM »
Safety alert...
Those lathe tools hanging on the pegboard behind the lathe are an invitation to reach across a spinning workpiece thus creating the opportunity to get wound up in your work.
Please do yourself a favor and rethink that storage plan.
