I don't like the idea of several separate "shops" you will be forever flitting back and forth between them which also adds to the problem of heating - do you heat them all or have one hot and then feel cold every half an hour when you go back into the other. I was looking at log stoves for the new workshop they are extremely effective in the house and a single decent stove could heat the entire area using waste wood that my friendly woodsman keeps dumping at my house1. Make the new large building your garage and store the motorbikes, lawn tractor and the car if you currently house that all in the new main building. Have a covered in link to this from the existing. It is over 100ft from that building to the first door on the house it is too far on a cold winter's night to want to park a car and walk to the house. I had considered using the new shed extension for the bikes, lawn tractor, potting shed and fruit/veg storage. 2. Move the big Colchester, Harrison and any other big machines into the front of the existing building. Add an insulated stud wall behind one of the garage doors and draftproof & insulate the other I was planing on adding another mill a bridgeport the existing garage does not have the head height
New main building has lawn tractor, bikes etc at the front and divided to give a big machine shop at the rear. No only the extension as only the end is south facing so it will be cold, the main building will have maximum south facing = light Existing shop then has more space and with the machines currently in that you can do the stationary engines and most of the BB1s. It has more than enough for me Still like the idea of a hot & dirty area this could be the small annex or a link building between the two larger ones. It is currently in the spare bay in the garage, the major boiler hearth is outside on the back of the garage wall Watch how much you increase the height as you will start needing planning if the ridge is over 4.0m tall. Also you start getting restrictions when you get to less than 1.0m from boundary so again may need to be a fraction narrower. I know I used to be a parish councillor, but this is a boundary onto agricultural land which means a different set of rules and the main garage only has a 4 m ridge this new building will be "smaller" Some would say you already have two workshops if you include the house facilities
Having had a look at your workshop on photobucket my thoughts would be. (may be worth posting them here so people can see what you have to work with)
I mentioned in my original thread about my workshop: http://www.modelenginemaker.com/index.php/topic,839.0.html that I had sufficient space behind my current garage/workshop to build another shed workshop. Well yesterday I took the tape measure out to see what was possible . If I assume I want to leave say an 8ft clearance gap (for bringing models around into the play area) between this new building complex and the old garage I have 32ft of good building space. I don't want it too deep, the current workshop 21ft length is a bit long as it needs the lights on at the far end during dark winter's days. 16ft wide would fit nicely sort of ?corner to corner? to the main garage. But then I thought I could add an annex at right angles along the far boundary say 10ft wide by 20ft, which would allow the workshop area to increase if I wanted without have a visual impact on the garden . Now a 32ft by 16ft workshop is a little bit big to heat so maybe I need to split it up. I definitely need a decent pair of doors on the end to allow large machine tools to be brought in, double glazing. Then there is the need for a storage area for all of those come in handies .JO,Please tell us why you want to build this shed? What do you want to do there? (in as much detail as you can)How would this relate to your overall shop needs?Please put down the soft needs (such as warm, light, comfy, hide-out, etc.) as well as the usual quantifiable ones (2 lathes, storage, electric, refrig, etc.)This will help you and us to understand what you should build. MoseyEarly thoughts any suggestions from anyone? And yes the double doors will have vehicular access .Jo
