Author Topic: My Demon V8 build  (Read 158080 times)
Offline Doc
  • USA ND
My Demon V8 build
« on: December 15, 2012, 02:59:14 AM »
Well I got a little shop time today.  Been working on this a little here and there when ever I can get some free time.
« Last Edit: February 08, 2014, 04:53:35 PM by Doc »
Offline Jim K 324
  • Morgan Ciy, La. ( On the Atchafalaya River)
Re: Shop time
« Reply #1 on: December 15, 2012, 03:19:04 AM »
           Real nice looking block Doc !! Looks like you have the chips flying now  :pinkelephant: Keep e'm
       going!!!!
        Regards   Jim
It's not what you make,It's how you make it that
matters !!
Offline Doc
  • USA ND
Re: Shop time
« Reply #2 on: December 16, 2012, 01:11:51 AM »
Thanks Jim!
I started on the heads today. Got to play in the shop most of the afternoon. Got the material sized up and hole patterns started.
Offline Doc
  • USA ND
Re: Shop time
« Reply #3 on: December 16, 2012, 07:48:16 PM »
Well got to play with my CNC this morning, worked on the heads for the v-8.
Re: Shop time
« Reply #4 on: December 16, 2012, 07:52:37 PM »
That's really coming along there Doc!
Re: Shop time
« Reply #5 on: December 16, 2012, 09:27:13 PM »
Looking good Doc. Pretty small!
Seems like I remember you from a past forum?
Offline Doc
  • USA ND
Re: Shop time
« Reply #6 on: December 16, 2012, 10:27:40 PM »
Yes, I did a couple build threads back there I believe I posted them here also (I think I did anyway).
Offline Doc
  • USA ND
Re: Shop time
« Reply #7 on: December 27, 2012, 03:16:16 AM »
Well got a little more shop time and played with my CNC  machine a little. I built a fixture to hold the cylinder heads and did some milling on them plus did get the timing covers done except for the crank seal bore. I'll bore that after they are assembled to the block to insure the seal will in the correct position. Hope to get out in the shop tomorrow and finish up the heads to the point of getting the valve cages made. I need to get some material ordered for the cylinder liners I'm thinking of going with some cast iron liners.
Offline metalmad
Re: Shop time
« Reply #8 on: December 27, 2012, 11:54:39 AM »
Hi Doc
Your flying along with those little lovelys :pinkelephant:
Offline Doc
  • USA ND
Re: Shop time
« Reply #9 on: December 28, 2012, 11:40:46 PM »
Well only a couple more days then shop time will be at a premium again (Christmas break will be over) :(
Got a little more done on the heads today I put off the 0-80 tapping until tomorrow. Then maybe set up and drill the exhaust and intake ports.
Offline Doc
  • USA ND
Re: Shop time
« Reply #10 on: January 01, 2013, 11:12:12 PM »
Last day in the shop for awhile I did get some things done though. Was a busy day.
Got a start on the rocker arms made up a holding fixture and mill out some blanks.
plus got the valve cages done and installed in the heads.
Re: Shop time
« Reply #11 on: January 01, 2013, 11:19:09 PM »
Who Doc!  Your moving right along!
Offline Mosey
  • Rosemont, New Jersey, USA
Re: Shop time
« Reply #12 on: January 01, 2013, 11:32:42 PM »
Wow is right, you're smokin.
Now I think you have extra cages, there. Do you have my correct address?
Mosey
Offline Doc
  • USA ND
Re: Shop time
« Reply #13 on: January 07, 2013, 08:36:46 PM »
Ok I have a question I would like some feed back on.
I'm about to start making valves and am thinking of taking a chance and using material I have no clue as to the composition. (framing nail to be exact)
They seem to turn pretty nice. I would just hate to have them not workout in the end.I usually use a good tool steel like a-2  with no heat treat for my valves. But if this works out it will save some turning time and they are a cheap source of material.
  I'd like to know whats your thoughts on this or should I just go get some material that I know will work out?
Offline KB
Re: Shop time
« Reply #14 on: January 07, 2013, 09:40:34 PM »
Beautiful work Doc!
One for you and one for me, right?
