Time to track down some old Tangye catalogues me thinks. Did John Bertinat do a different version of this to Westbury? or was it mainly the marine engines he did.
ME 4278 has a few of the Double Tangye variants, interestingly Dave Piddington says Westbury based his on one that is shown with a single governor, also the GA on my Hobby Store seems to show a single governor?? A read through of Westbury's build series may throw some more light on the subject.DP's article also says that Bertinat designed a compound, now that would make an interesting project if they are raw castings you have been looking at and not that completed one of Alan'sAlso ME Vol 68 had a design for another Double, I expect you have copies.J
I'm sure you can look at 2278 on line while you pretend to be working its in the digital archive
Some had Aspinall Governors fitted but it was more an overspeed trip than a governor. I served in an oil tanker with one fitted and it was a right royal pain in the arse until we disconnected it. In heavy weather the prop would partially, sometimes almost fully, leave the water, especially when in ballast. Needless to say this was fairly exciting. The trouble was when the Aspinall tripped the ahead throttle the bloody thing had to be wound fully shut to reset the trip and then opened up again. The throttle handwheel was some 4ft diameter and drove a heap of rod gearing and bevel boxes up to the actual valve and was heavy going especially when trying to do it quickly. When the stern went back under the water the prop kinda stopped hence the haste. We found we could shut it enough by hand to prevent a dangerous overspeed before the ocean got another grip on the prop.Just another little insight into the joys of engine room watchkeeping.Best RegardsBob
And if the governer happens to shut it down on TDC when the prop went back in....your glued, screwed and tattoo'd!....unless the Engineer of the watch is on duty at the throttle!...... Dave
..... they do almost all seem to have the pickering governors. Are you on Traction Talk?
Quote from: steamer on November 29, 2012, 01:45:09 PMAnd if the governer happens to shut it down on TDC when the prop went back in....your glued, screwed and tattoo'd!....unless the Engineer of the watch is on duty at the throttle!...... DaveActually no, remember the impulse valves and where else would he be at such a time, ( apart from looking for a bucket). Best RegardsBob
Last week I was tempted by a young man to go and see his castings , well I liked them so much that I felt the urge to have to take them home The set of castings in question is for a model Westbury Double Tangye Mill engine. It is a fairly simple engine but it has one feature that is pussling me: it has two governors each controlling a piston valve throttle:I know that these engines were originally made as colonial engines and the idea was that as they were relatively small you could run them as either a double or as a single if you dropped off one crank and eccentric. But would that not have worked if there was a single governor and throttle? Jo
....ie hey if we put 2 govenors on this engine we can charge double the price.... simple really
One thing that really annoys me when you go to try to buy a part built model is that expression "It was started by a toolmaker". Well either I have unreasonable expectations of the abilities of toolmakers over novice model engineers or toolmakers these days don't have the hand skills they one day had. May be they are talking ......I am sure I am not blond.... Jo
Yes a good many castings are untouched. Now the question was what to do with them
Jo with all those castings under your bed do you have it raised up on blocks and have to mind your head on the ceiling when you sit up in bed? Maybe you misheard the description of the previous builder and the seller said "it was made by a tool"
.....and store them in the library.....
My Cowell's is in the library .Jo
Watch out for that man, he Will try and talk you out of a PE and make you build his Wallis, he's been trying to get me to do one for ages.Why not butcher his 2" compound A7 into a farmers engine saves having to sort a cylinder for the 3" then everyone is happy
Shall we Start at the beginning of the alphabet, so that would mean you need to bring along your Aciera : I could do with a F1 fix now that the season's finished.Jo
Be careful of the "big jobs" Jo.....they are all encompassing....and they get more expensive to the cube of the scale......ask me how I know this.... Dave
Go and knock on his door, he does not live far away, Oh then again maybe not you could be tempted by the sight of his 4" Burrell and the 3" Fowler Showmans he has there
Best not tell you to look at the for sale ads on TT, 2" AA7 and a Z2?
The very small scales are really showcase models you need at least 2" for it to work and larger really if you want to shift some dirt. Even in 2" you need to think about lifting gear especially if like my Superba its got a steel boiler
Quote from: Jasonb on November 29, 2012, 08:39:28 AMME 4278 has a few of the Double Tangye variants, interestingly Dave Piddington says Westbury based his on one that is shown with a single governor, also the GA on my Hobby Store seems to show a single governor?? A read through of Westbury's build series may throw some more light on the subject.Thanks, I will have to dig out that copy of ME when I get home... Now it is the original Westbury article that I suspect is the source of the twin governors problem rather than original engines, but I hope someone will be able to enlighten me. The GA as you say shows a single governor but as you get to the pages about building the governor they show all the parts as needing twice as many as you really need (ignoring the fact that the governors don't look very original )
