Author Topic: Out of the junk box  (Read 5446 times)
Offline doubletop
  • Wellington NZ
Out of the junk box
« on: November 18, 2012, 08:24:41 AM »
I needed a piece of bronze and had something that was just the job. So I spent an hour or so making the parts and then went to the hearth to do the silver soldering.
The job went black an then this happened. (I cut off another piece to show you)
<a href="https://www.youtube.com/watch?v=jZYMv7N2aa8" target="_blank">http://www.youtube.com/watch?v=jZYMv7N2aa8</a>
I assume its something like Oilite
Using scrap isn't always the most cost effective option. I now need to remake the job.
« Last Edit: November 18, 2012, 08:31:18 AM by doubletop »
Offline tel
  • Bathurst District, NSW, Oz.
Re: Out of the junk box
« Reply #1 on: November 18, 2012, 08:34:06 AM »
Certainly not your ordinary bit of bronze.
Offline sbwhart
  • Live Long and Prosper
« Reply #2 on: November 18, 2012, 09:03:59 AM »
Can't see the picture Pete
But it could be ally bronze to check it out try a strong magnet on it if its ally bronze it will be slightly magnetic.
You have to add 50% salt to the flux to solder ally bronze never tried it though.
Stew
« Reply #3 on: November 18, 2012, 01:16:22 PM »
I would have to agree with you on it being oil impregnated bronze, else it wouldn't have stayed lit with the torch removed. Good stuff on its own, but obviously not good for silver soldering.
« Reply #4 on: November 18, 2012, 03:04:18 PM »
Looks like sintered brass Pete, probably a bushing out of an appliance. It is full of oil.
Offline doubletop
  • Wellington NZ
« Reply #5 on: November 19, 2012, 06:00:48 AM »
Stew
Hopefully the video is working for you
It was certainly full of oil but it wasn't an old bushing, it was just a piece of bar
It certainly had me thinking at the time but it seems to fit the description of Oilite  http://en.wikipedia.org/wiki/Oilite
It did get it to silver solder once the oil had burned off and I cleaned it up, but it wasn't much good as a steam valve, it leaked a bit through the metal
« Last Edit: July 16, 2017, 09:15:27 AM by doubletop »
« Reply #6 on: November 19, 2012, 01:45:39 PM »
Sintered Brass is porous Pete and made to absorb oil.
« Reply #7 on: November 19, 2012, 02:26:22 PM »
Looking at the texture of the finish it does look like sintered bronze. Well worth putting in a labeled bag for when you need it.
