As many of you know I have been involved with on line machining forums for a few years. We all know the same questions often re-appear. I started a similar thread on another board but decide to let hte folks here have a go at this.
So here is the concept . we are going to set up machinist tools box suitable for the home shop machinist / Amateur Engineer /Model engine builder.
so here are the rules : place a tool into this virtual tool box.
(1) Limit one tool per thread . Three tools per person.
(2) This must be a tool you have in your shop and use, like and would recomend to a friend.
(3) Post a photo of the tool. your photo or link to manufacturers or sellers web site. give credit for the photo if not yours.
(4)list price and availabity as much as possible.
(5) explain the tool ,its uses and what you like and limitations. Tell us why you think this is a must have tool for the tool box.
(6) the focus here is filling the virtual tool box but you may post something that does not fit in the box.
(7) I hope this to be a fun and educational experience for all.
I will start with a tool box that is readily availble in the USA and I believe to be a good bang for the buck especially if you have a coupon .
Name Eight Drawer Wood Tool Chest
SKU 94538
Brand Windsor Design
Drawers 8
Material Wood
Shipping Volume 2.992
Overall dimensions: 20" L x 10-1/2" W x 16" H
Shipping Weight: 20.65 lbs.
Import from China
Manufacturer Warranty Detail 100% Satisfaction Guarantee! If for ANY reason you are not satisfied with this item, you may return it within 90 days for a full refund or replacement.
regular price $99.99
my price after coupon$ 59.99 40% discount.
This is advertised as hardwood with a walnut stain.
The box appears to be solid wood if there is any laminate it is well hidden. drawer bottoms masonite type material with IMHO a few too many staples holding then in. As far as walnut finish I am not seeing it looks more maple color to me.
The hardware is advertised as chrome plated. It is there and looks good . The knobs on the display model appeared to be turned aluminum and had a home /shop made appearance. The single handle on the box is on the top a modem version of the handle on top of my vintage union box. There is no lid support in the till. Something that can be added like I did on my Travers import box. The item description mentions single key locking. this is a normal feature for such a box, but not true. this box has two locks each with a pair off keys, one for the till and a second lock for the drawer covers. There is an ugly do not remove this label label inside the drawer cover with the box serial number on it. The box is felt lined the Mrs says the felt is thin, not something I noticed.
I mentioned drawer bottoms.In comparison my vintage union has tin plate steel for drawer bottoms. My Travers import box has thin ply wood that is captured by the drawer frame. My son's Grizzly box has masonite held with one staple . Remove the staple slide out the drawer bottom and replace with something better.The drawer bottoms on this one will slide out after removing the one staple per inch of drawer. arg.
If you want Gershner Quality and can afford it buy a Gershner. if you want a value priced import to hold your hobby tools this is IMHO a good value. Add a lid support ,replace the drawer bottoms with aluminum or tinplate steel and you will have a pretty nice box.
Harbor Freight stock Photo
Thanks for reading. normal disclaimer no affiliations Yada Yada. caravat Emptor I inspected the condition of my box before leaving the store parking lot . I recommend the same for any similar purchase.
Tin
